[volkswagen crafter 10/2018 2.0cc DAU 103Kw Diesel] P0299 REGOLAZIONE DELA PRESONE DI SOVRALIMENTAZIONE
VAI ALLA SOLUZIONE Risolta da autofficinanic,
BUNGIORNO HO QST FURGONE IN OFFICINA CON CODICE GUASTO P0299
IN MARCIA SI STACCA LA CORRENTE SOPRA LA VOLVOLA CHE COMANDA LA TURBINA E MI RILASCIA LA WASTEGATE
HO PROVATO HA SOSTITUIRE LA VALVOLA E NIENTE HO PROVATO A STACCARE IL FAP E NIENTE SEMPRE UGUALE
HO PROVATO HA STACCARE LA WASTEGATE DALLA TURBINA E LA GEOMETRIA E LIBERA
  • Risposte 11
  • autofficinanic
  • carlito
    Domm
    Domm
    438,3k
