[Alfa Romeo 159 06/2009 1968cc 939A2000 110Kw Diesel] si spegne
VAI ALLA SOLUZIONE Risolta da ro.ma.car,
SALVE A TUTTI RAGAZZI HO UN PROBLEMA CON QUESTA ALFA ARRIVATA IN OFFICINA NON PARTIVA FATTA DIAGNOSI AVEVA IL FAP COMPLETAMENTE INTASATO SISTEMATO IL PROBLEMA LA MACCHINA PARTE E RIMANE AL MINIMO DA FERMO LA MACCHINA VA BENEISSIMO COME SI PROVA A SPOSTARE LA MACCHINA SI SPEGNE. SE STACCO IL CONNETTORE DELLA POMPA ABS LA MACCHINA E PERFETTA SOSTITUITA LA POMPA ABS STESSO PROBLEMA LA VETTURA MARCIA SOLAMENTE CON LA POMPA ABS STACCATA. RINGRAZIO IN ANTICIPO UN SALUTO
  • Risposte 28
  • ro.ma.car
    10
  • il re dei irni
  • pierdavide
    bibby
    bibby
