[BMW X5 E53 3.0D 09/2006 3000cc E53 160Kw Diesel] X5 E53 ENGINE sometimes
Hello everyone,
I have a bmw x5 3.0d E53 of the year 2006. The car starts sometimes. When I make contact and the temperature needle goes to the maximum, it does not start, also the DDE warning light comes on. When I make contact and the temperature needle stays in place, it starts, and it goes perfect.
I have exchanged the two blue relays, and it continues to fail. I do not think the two are in bad shape.
http://i67.tinypic.com/2jdnigj.jpg
When the temperature needle is at its maximum, I try to connect the diagnostic machine and give "communication error", when it works fine if it leaves me.
I only have error codes in the Instruments box
F6
F8
F4
F9
CAN Identification missing.
Anyone know what can it be? I read through a forum that was a switchboard problem.
Sorry for my english i use translator
In this photo the car would turn on
http://i65.tinypic.com/jhpki8.jpg
In this photo the car would not turn on
http://i67.tinypic.com/2rwl3eg.jpg
hola a todos,
tengo un bmw x5 3.0d E53 del año 2006. El coche arranca a veces. Cuando pongo contacto y la aguja de temperatura se va al maximo, no arranca, tambien se enciende el testigo DDE. Cuando pongo contacto y la aguja de temperatura se queda en su sitio, arranca, y va perfecto.
He intercambiado los dos reles azules, y sigue fallando. No creo que los dos esten en mal estado.
Cuando la aguja de temperatura esta al maximo, intento conectar maquina de diagnosis y da "error comunicacion", cuando funciona bien si que me deja.
Solo me queda codigos de error en Cuadro Instrumentos
F6
F8
F4
F9
Alguien sabe que puede ser? He leido por un foro que era problema de centralita.
  • Risposte 25
  • AutomocioRicard
    10
  • francesco ardito
  • commodore
    Top Garage
    Top Garage
    444,4k
