[FORD PUMA 11/2020 1.5cc ZTJE 88Kw Diesel] SPIE AVARIE MOTORE ABS, ANTICOLLISIONE
BUONGIONO HO QUESTA MACCHINA IN OFFICINA CON I SEGUENTI PROBLEMI SPIE MOTORE, ABS, ANTICOLLISIONE, ECC TUTTE ACCESE.
LA MACCHINA SU STRADA VA BENE, FINO A QUANDO NON ACCENDONO QUESTE SPIE E VA LENTAMENTE A FERMARSI FINO AL PUNTO DI SPEGNERE L'AUTO E NON RIPARTE (NON GIRA IL MOTORE), SOLO DOPO AVER FATTO IL RESET BSM RIPARTE CON TUTTE LE SPIE SPENTE E RITORNA A FUNZIONARE TUTTO COME PRIMA, DOPO QUALCHE KM SI RIPRESENTA IL TUTTO. IN ALLEGATO DIAGNOSI CON TUTTI GLI ERRORI IN CENTRALINE, E' STATO CAMBIATO ALTERNATORE IN QUESTI GIORNI E BATTERIA L'ANNO SCORSO. MA SENZA RISULTATO POSITIVO https://ibb.co/qrHyk4X https://ibb.co/wwj9X28
A QUALCUNO E' SUCCESSO?
  • Phoenix ha cambiato il titolo in [FORD PUMA 11/2020 1.5cc ZTJE 88Kw Diesel] SPIE AVARIE MOTORE ABS, ANTICOLLISIONE
  • Risposte 9
  • sammito
    Enea98
    Enea98
    444,5k
