[FIAT PANDA 06/2007 1248cc 188A8000 51Kw Diesel] PROBLEMA LINEA CAN
SALVE COLLEGHI, HO UN PROBLEMA CON QUESTA PANDA 1.3 MTJ, NELLA MACCHINA RIMANGONO LE SPIE DELL'ABS ACCESE, QUELLA DELL'ELETTROGUIDA E LO STERZO APPUNTO DURO, IL TRIANGOLO DI PERICOLO, E IL CONTA GIRI NON SALE, PERO' LA MACCHINA SI AVVIA PERFETTAMENTE. IN DIAGNOSI CON IL BRAIN-BE TROVO I SEGUENTI ERRORI: CENTRALINA MOTORE U1600 IMMOBILIZZATORE; U1601 LINEA CAN-BUS OFF, NEL BODY COMPUTER: B1019 VELOCITA' VEICOLO (CAN) NON VALIDO; U1601 LINEA C-CAN BUS OFF; U1600 MINIKRYPT CODICE ERRATO; E NELLA CENTRALINA DELLO STERZO E DELL'ABS TROVO SEMPRE LINEA CAN OFF. HO CONTROLLATO I PIN 6-14 DELLA PRESA OBD E NON TROVO NESSUNA RESISTENZA, HO ANCHE FATTO VARI CONTROLLI SU TUTTO IL CABLAGGIO E NON RIESCO A TROVARE NULLA. A QUALCUNO E' MAI CAPITATA QUALCOSA DEL GENERE?  GRAZIE MILLE A TUTTI IN ANTICIPO
  • Risposte 17
  • DAguanno Stabile
  • rikymoto
  • elettrauto1
    bibby
    bibby
